how can i get the higher voltage than power_supply ?
qqmz
Junior Member level 3
now ,the power_supply is 3v in my circuit ,how can i get the 5v or 7.5v voltage , if i need to use a charge pump or other circuit structure? i do not have the experience related to this , expecting your advices!!!
thanks first!!!
Depending on current that you will require at the higher voltage level, you can use a charge pump such as for example: **broken link removed**
or you can build an inverter such as: http://www.aaroncake.net/circuits/6-12conv.htm (some values need to be changed in order to operate correctly of 3V)
Regards,
IanP
Yes, the charge pump design can meet your requirement. And the current consumption is most important spec for the charge pump.
in the simplest way, you can build an oscilator such as 555 and drive a little transformer such as impulse choke core and with ratio of turn deliver the desire voltage at output.
if you still havea problem reply to upload circuit.
use L and c
and extra device
If you need less than 100mA, use a switched capacitor circuit. They are made by linear technology, analog devices, national and others. For more current, you will need a switching regulator with a coil or transformer. Look at the same manufacturers for this.
thanks for all your helps !!!
better prefer the other options than the charge pumps becoz designing of the charge pump at time is a bit difficult
You can think about these item
Charge Pump:
Low Nosie , light load ,Small Area
Boost PWM/PFM
Heavy Load ,Fast Load Transient (need inductor)
Maybe some DC-DC converters which are available as black boxes suite the need.
