How can I get Gm for a MOSFET in ADS?
boy
Advanced Member level 1
Thailand
I have read some tutorials. I saw in the DC simulation controller that in Other, they can set something like M1.Gm to get Gm for the MOSFET but I dont know how to set it. Also in TSMC library, how can I get Gm, Cox, Tox for the MOSFET in ADS, thank you very much.
in @DS U can use a meas equation component
and gm=GM.mosfet1
mosfet 1 is the name of the transistor
or u can make it by using differentiation of IDs with respect to VGS
and about cox u can see the examples in RFIC , the vco with mos varactor there is a design using s parameter simulation to find cin of the mos
but tox , is a parameter of the technology i think for TSMC .18 it about 4nm
Thank you very much, it works, actually gm=M1.Gm :) BTW how can i know what parameters in the model that I can extract??? I have tried help but it does not say much about that. it seems to me that i can have something like, M1.xxx to get the paraneters but i wnat but i dont know how many and what xxx ??
About RFIC example, i run the schemetic Biased_FAT_CAP_Test, i saw the Cin, can i also use this for Cout?? Actualy, i would like to design a distributed amplifier. I wonder that can i use those Cin and Cout from that technique to get Cin and Cout for the distributed amplifier. thank you
i think u can do this for cout , as u calculte output imedance of the amp and the imaginary part is the capacitance
and also ask an experinced designer , he may know better
Sorry!
Attachment here
Plot Ids-Vds curves. To calculate gm, use the command
gm = diff(Ids) in the data display. This will give you the derivatice of Ids w.r.t. Vgs which is basically, gm.
choose Amplifier O' ADS design guide ,there is a templete to caculate the gm.
you must get some sense before your design
gm is the transconductance, just use to descrip the Ids v.s. Vgs!
so did simulation use dive...
Double click DC Pallete->Parameters Tab->check Detailed Device Operating point Level., then go to graph window, add a rectangular window and you finally see gm and someotheruseful intrinsic parameters.You can plot anything vs anything.Be careful with indepented vectors .Must be same and equal!!!
