Hishamsaleh
Full Member level 1
problems & problems..... that's how we learn...
ok.. I have Creative PCI V90 modem... something happened to the phone line (I think high voltage chock) and after I got no dial tone message when I use it... the problem was: zener diad has beed dameged. so i change it and everything is ok now...
another modem stopped also... and the same msg... but everything (hardware) seems to be ok... I tried to listen to the line while modem tries to open port and connect, I heared some pulses not more than 4/sec... like if the modem tries to open but can not keep opening it...
What do you think the problem is??
the second modem is ACORP AMR1 65000...
thanks for helping
thanks for helping
