giorgi3092
Junior Member level 2
I am given this circuit:
I draw small signal model like this:
Then, I am not sure how to write the KCL at the emitter.
A good samaritan online told me that the correct KCL would be:
v_pi/r_pi + gm*v_pi + i_x = 0
which yields R_in = v_x/i_x = r_e = V_T/I_C*alpha. which seems to be correct because I simulated in LTspice with typical values and calculations and simulation results match. Both gave 25 Ohm for I_c = 1mA, B=100 transistor.
What I cannot understand at all is why we leave out the current that flows thru r_o??
My naive KCL would be:
v_pi/r_pi + gm*v_pi - gm*v_pi + i_x = 0 so, I would also write the current that flows out of the node thru r_o, simplifying to v_pi/r_pi + i_x = 0, which gives R_in = v_x/i_x = r_pi which is totally WRONG!
Can anyone explain the weeds of this circuit? and why we leave r_o out of the KCL equation?
Thank you
Thank you
