have a signal generator and need to mount a sinusoidal wave in a 2.5V DC value but the instrument does not provide this level of offset. How can design a bias-tee for a frequency from 500KHz to 20MHz. Commercial bias-tee are too expensive :| ($100usd or more) suppliers like minicircuits. Someone to know a website with cheaper bias-tee ?
I'm not sure if connecting generator and power supply in series is correct.
connecting power supply and generator in series wouldn't cause any problem if you are using supplies below the function generator's input dc supply roughly 15 to 20 volts.... i have tried this....
