How can I check if the Millers theorem is applicable?
Hackson
Junior Member level 1
Miller's theorem
How can I gurantee Miller's theorem is applicable. Razavi's book just states that it is not always applicable. So, when is it applicable and when is it not?
Miller's theorem
If there is only one path for signal, it's not applicable.
Re: Miller's theorem
That was just one case, according to razavi there cud many situations when miller theorem can not be used.
It seems to me that every theorem is the form :
A=> B
so if B is that the impedance can be decomposed into two impedances connected to the ground, then what is A?
find a mosfet basic article ,you can find it theory.
IR,Fairchild all have such application note.
Maybe the limitation is the phase-frequiency response of the amp.
If the phase is not 180 deg,e.g. at HF,the formula is not exact.
Hey buddies,
I've just found out that Miller theorem can be applied only when the impedance Z in interest doesn't cause any change to the gain between X and Y. That's why razavi says that if Z is not the main signal path, Miller's theorem can be applied. :)
