How can I calculate the following integral??
reza1001gh
x0 , T are constants
Please help, thank you for your help in advance
reza1001gh, I can't see any text associated to this thread. It seems empty
A board software problem occured when the OP edited his post.
Parameters T and n are constant numbers, so that you should integrate something in the form of \[{ sin(x)}^{4n}\].
Check this pattern here:
We know that
sin(a)*sin(b) = cos(a-b)/2 - cos(a+b)/2
if a=(x+xo)*T and b=(x-xo)*T then:
sin[(x+xo)*T]*sin[(x-xo)*T] = cos(2*xo*T)/2-cos(2*x*T)/2
the first term doesn't depends from "x" so it is costant. calling it "k" we will have:
sin[(x+xo)*T]*sin[(x-xo)*T] = [k-cos(2*x*T)]/2
so we will have to integrate:
{[k-cos(2*x*T)]/2}^(2*n)
if "n" is an integer number, the integral can be calculated using the reduction formula (https://en.wikipedia.org/wiki/Integration_by_reduction_formulae). It is quite tedious.
