reza1978
Newbie level 5
Hi all,
I designed an 32kb SRAM with its decoder, sense amplifier and .... and wrote its netlist with Hspice Now I want to calculate its dynamic power. I have some problems:
1- How should I calculate its dynamic power when the inputs are pulse?
2- Maybe one way is that I calculate the total capacitances in each node and use this formul: P=C×f×Vdd² but the problem is that when I use for example:
.PRINT CGG=LX18(OUT)
there isn´t any result in .LIS file or in .MT0 file,
so I can´t understand how I should calculate the capacitances in the transient mode.
3- When I put .OP in the netlist I saw total capacitances for all transistors but the problem is that they are for DC mode. Can I use these results for transient mode?
Thank you in advance,
Reza
Reza
