how can design the ptat ?
qqmz
Junior Member level 3
hello:
how can decide the parameters of the mos-transistor? the circuit schematic is in the razavi's book "the design of analog integrate circuit" page 325, 11.31(b) .
i want to get a 50uA , i got the value , but the value change a lot when i choose the different power such as when i change the power from 3v to 2.7v ,the value change from 50u to 35u ,why ?
thank you !!!
Whitout seeing the schematic I guess either some of your transistors are operating in the linear region or their channel length is much too short.
now ,i got a value 50 which do not change too much with the power, but it change a lot with the temperture, such as it change from 40 to 70u when the temperture change from -25 to 125,
why ?
maybe yous circuit model changed with temperature,
if you want get good current ,maybe VBG add BIAS is best
maybe i need to choose one vbg add bias circuit to get a good current source ,
the ptat changed too much with the temperture !!!1
use current bias the circuit
maybe amp is operating in the linear region.
