How best to hardware reset or restart a SIM300 (or SIM900)
Aaron2
Junior Member level 3
I'm using a manufactured MCU board with a SIM300 module, and need to do a Reset or power cycle of the SIM300.
I need to reset the SIM300 every 10 days. For some reason the SIM300 controller board will send a daily test message for 11-12 days reliably, then fails, and is not reliable again until the unit is restarted. (the network indicator LED is flashing fast or off at times when failing.)
I have a tiny MCU/RTC board of my own design I use for triggering the SIM300 board for a daily test, so I can create the SIM300 reset with another output from my MCU/RTC board. I don't have access to the SIM300 board's MCU software/code, so I'll have to do this externally.
Any suggestions appreciated.
I'll be testing the below unless there is a better suggestion.
my sim300 is restarting after 10 sec what circuit id required to provide the same? im using 12v 500mA adaper followed by 7805IC and a 1n4148 diode
