How and where to start learning Verilog HDL
Edward_2288
Member level 4
Verilog HDL
Hi all,
i would like to learn Verilog hdl.
so can you give me some suggestion how and where to start? and what is the best and most effective way to master it?
Thanks
Verilog HDL
Hi
There's a book <verilog hardware design language>
will help you!
zhpy
Verilog HDL
what is the book?
Verilog HDL
you can start with <<hdl chip design>>
good book
Re: Verilog HDL
i recommend you Verilog HDL Synthesis A Practical Primer
if you can't find it p.m
Re: Verilog HDL
Verilog HDL--Guide to Digital Design & Synthesis (2nd)
you can find it in EDA BOOK UPLOAD !!
Re: Verilog HDL
Hi.,..I cannot find it..
would you mind to specify in which section it is?
thx
Verilog HDL
Start it step-by-step:
1. Learn HDL coding but always imagine the code in real circuit.
2. Program some simple design and have good experience with EDA software.
3. Study the details of FSM design.
4. You can guide yourself in this stage.
Re: Verilog HDL
Yes, you said it.
And if you do more practice, you will master it more rapidly.
Re: Verilog HDL
The verilog HDL book by Samir Palnitkar is really good to know the innards of verilog. The primer is also a good one to start but there is no problem if you start with the one above. It has some good examples and is quite in depth. As verilog is similar to c in coding styles its easier to learn but the thing to keep in mind is that you are designing a piece of hardware which makes it different from actual c-coding.
Re: Verilog HDL
I think you should find a project source code to learn verilog.
you must keep verilog is used to descript hardware in your mind
Verilog HDL
I only recommend you to not learn verylog programming itself...instead programming and synthesis both of them.for verylog programming you should think HARDWARE not only software!
Verilog HDL
Hello,
Check out these two links, it will be definitely usefule for you.
http://www.deeps.org/hdl_models/index.html
If you want to buy some books,...,
for the biginner,
VerilogPrimer - J.Bhaskar
VerilogSynthesis - J.Bhaskar
These two are good ones for learning.
Re: Verilog HDL
Here were lot of suggestion. let me give few cents of mine.
1) Take up a HDL book on verilog
2) solve all example that you can and you feel intresting.
3) Choose some small design (UART, ALU, GAME DESIGN, etc)
Try to make a proper document (microarchitecture doc), and then start
coding. Put efforts on developing a testbech also ..coz that will tell you how best have you designed.
4) If you are more enthu place the design on a FPGA and check for real world problems.
all the best,
Cheers,
Gold_kiss
