Well, I try to explain how I see it.
- If we assume, that there were some dc running in the rotor, that would be magnetic, and thus then there would be a voltage generated to the stator, right?
- So, if the alternator would generate power, for its rotor, it would generate for its outputs as well.
The trick is thus to understand how it all STARTS, as there has to be some way of generating the magnetization of rotor first place! We don't have a battery, and magnetization of rotor has to be maintained by current from the stator, which is initially zero. Then I thought: Which was first, an egg or a chicken? You don't get chickens without eggs, and eggs without chickens.
However, we have here a solution of type Deus Ex Machina (See
https://en.wikipedia.org/wiki/Deus_ex_machina, if you want to know what that Latin phrase means. I think the explanation on top of that article is quite fitting):
Surprise surprise, there is something called remanence (or residual magnetism) in the (rotor's) iron: It is NEVER totally un-magnetized. So there is weak magnetism in the rotor, which during start of mechanical motion generates a weak current to the stator, which is rectified and fed to the rotor, making its magnetism a bit stronger, and thus stator is generating more current ... etc. And suddenly everything works as it should, the alternator is generating plenty electricity for its main output, too!
Does this story help you?
-Ted
