How add user defined header file to project
PA3040
Advanced Member level 3
Dear All,
I need add continuously use program subroutine as header file to my project folder
Example In Assembly
delay subroutine is using continuously, therefore I need use delay subroutine in separate file and add to main program like we add processor register file (#include <p16f877a.inc>)
Hopefully anybody understand what I need is
My MCU is 16f877a
Language is Assembly
Please advice
Thanks in advance
PA3040
Back with assembler ?
Example attached.. for 18Fs but think on the 16F you might have to place the #includes at the beginning of your main code with after the list.
  • delay.rar
Reactions: PA3040
    PA3040
dear wp100,
Thanks for the reply
I did it like this and "delay.inc" file include to the project folder
status		equ		0x03
trisc		equ		0x87
portc		equ		0x07
__config 3f39
[COLOR="#FF0000"]#include delay.inc[/COLOR]
start		goto	main
main		call	sys_init
			call	led_on
led_on
loop		movlw	0xff
			movwf	portc
			[COLOR="#FFA07A"]call	delay[/COLOR]
			clrf	portc
			goto	loop
sys_init	bsf		status,5
			clrf	trisc
			bcf		status,5
			return
then following error is occurring, please help
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F877A "test.asm" /l"test.lst" /e"test.err" /d__DEBUG=1
Warning[205] C:\BATCH1\TEST\TEST.ASM 6 : Found directive in column 1. (__config)
Error[113] C:\BATCH1\TEST\DELAY.INC 10 : Symbol not previously defined (d1)
Error[113] C:\BATCH1\TEST\DELAY.INC 12 : Symbol not previously defined (d2)
Error[113] C:\BATCH1\TEST\DELAY.INC 14 : Symbol not previously defined (d1)
Error[113] C:\BATCH1\TEST\DELAY.INC 16 : Symbol not previously defined (d2)
Error[113] C:\BATCH1\TEST\TEST.ASM 17 : Symbol not previously defined (delay)
Message[302] C:\BATCH1\TEST\TEST.ASM 22 : Register in operand not in bank 0. Ensure that bank bits are correct.
Halting build on first failure as requested.
Debug build of project `C:\Batch1\test\test.asm.mcp' failed.
Language tool versions: MPASMWIN.exe v5.36, mplink.exe v4.36, mplib.exe v4.36
Preprocessor symbol `__DEBUG' is defined.
Tue Oct 23 23:46:12 2012
BUILD FAILED
Thanks in advance
I never forget Assembly
This should work for you - but check the osc in the config bits XT = 4meg and below
;status		equ		0x03     no need to specify - the 877a.inc file contains all the system registers
;trisc		equ		0x87
;portc		equ		0x07
			list		p=16f877A	; list directive to define processor
			#include	<p16f877A.inc>	; processor specific variable definitions
		__CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _XT_OSC & _WRT_OFF & _LVP_OFF & _CPD_OFF
;		__config 3f39   ??  this selects the RC osc, Watchdog Enabled and LVP on - which you do not want
;							use the full version as above so you can always see what bits you have set
			cblock 0x20			; specify user registers
			d1,d2,d3			; delay work files
			endc
			org 0x0000
			goto	main
			#include delay.inc
main		call	sys_init
			call	led_on
led_on
loop		movlw	0xff
			movwf	portc
			call	delay
			clrf	portc
			call	delay  	  ; also need a delay here otherwise the led will be on all the time
			goto	loop
sys_init	clrf	PORTC	; ensure portC is off.
			banksel	TRISC
			clrf	trisc
			banksel	0
			return
			end
Reactions: PA3040
    PA3040
Dear wp100,
Big thanks for the reply and more advice . also I understand that individual bit configuration is better than the use of config hex word. If you do not take anger I would like to more clear out the bit configuration that you pointed out with my suggestion. please see the picture
Please advice
Thanks in advance
PA3040
No, you are right, I read your hex config value incorrectly, sorry.
As you say is always better to list the bits in full, but if its a hex number then after building it, use MPlabs, Configure, Configuartion Bits to check the values.
Reactions: PA3040
    PA3040
