How 2 parallel 2+ 24LC256 EEPROMS
prinsloo
Member level 5
Member level 5
Bethlehem RSA
24lc256 connect
Dear friends
Do you know how to parallel 2 or more 24LC256 serial EEPROMS?
I need a lot of memory to store data for a pic project
mk2 pic electric meter.
Thank you
24lc256 and programming
Parrallel the I2C pins, and configure your address pins (1-2-3) for different addresses for the 2 chips. You can connect up to 8 devices parrallel.
Cheers
sda
diagrama 24lc256
Or instead of using 24LC256s you can use 24FC512, 24FC1024 or 24FC2048 etc
Each one doubles the capacity of the previous chip and they also can be connected in parallel (SDA, SCL) in sets of up to 8 (A0, A1 and A2) ..
24fc512 using spi
Hello
Why are you using the 24xxx memory use the M25Pxx from ST or Atmel with up to 8 MBYTE of flash memory using the SPI serial bus
www.ST.com or google for M25P10
All the best
Bobi
24lc256 with pic programming
Dear Friends
I can,t seem to find I2C pin.Pins marked are as follow-1-A0,2-A1,3-A2.4-GND,5-SDA,6-SCL,7-WP,8-+VE.(EPE mag Feb05).
I also need to change the PIC .ASM file to record to correct address of 24LC256,and I don't know how.File is to complicated for my little knowledge of PIC programming.
Regards
24lc256 address pins
1-A0,2-A1,3-A2. are the Adress
from 000 to 111 so 8 Eeprom possible
24lc256 programming
If I understand you correctly I must connect A1 to A1 to A1 FOR 3 chips together?How do I controll the writing to the chips-at present the program for the pic is set to 'roll over'
24fc512 how to
No you have to connect in parallel only SCL and SDA line of each chip.
The A0, A1 and A2 must be hardware connected to +VE and GND.
See this diagram:
Then you must use the control byte to address the chip.
What do you mean the program is set for roll over ?
pic 24lc256
I quote 'memory is controlled by pic pins RC3(clock) and RC4(data).data is transfered serially in response to the clock signal.Data pin is bidirectional ...The memory is accessed cycliclly,recording to memory bytes from 0 to 32K,then rolling over to zero,and then recording over the previous memory locations,up to 32K again,and so on.To maintain program simplicity in respect of rollover point,the number of bytes for each sample has been set at the "round" binary number of 16,....At each minute interval two bytes for voltage are recorded,two bytes each for both current channels,with two bytes left over.To one of these is recorded a "flag"which indicates at what point in the memory count is set to zero and ignored.'
I have fig 5.1,down loaded from Microchip,and data sheet.Do I have to change the .asm file for the pic to know that it must write to a certain address?
Is there nobody that can help me with my problem?Is it possible or just to difficult to change the .asm file?
