House made compressor
It is a one phase compressor that powers the motor of more than 1kW power. To activate the compressor, use the contactor, “system on-off”. The compressor was taken from URSUS tractor.
Quick release was mounted to the tank, so you can disconnect the spiral hose and change quickly the air pistol. The tank was taken from the Star truck. Pressure switch was adjusted so that when the tank pressure falls, the engine is able to start, because the engine start-up is based on the machine, which is located on the rotor axle.
Link to original thread (useful attachment) – Sprężarka (Kompresor) produkcji domowej.
