mobus1
Hello Folks, here's a unique challenge I dealing with.....
Please bear with my lack of knowledge.
I'm trying to find a way to power a 82 vac, 300 watt project lamp from 120 vac.
The lamp/lens assembly is salvaged from an old Kodak slide projector. The lamp power was obtained from a fan motor winding in the original projector.
I am building a custom projection system using multiple lamp/lens assemblies.
The surplus units I acquired did not include the fan motors, so I need to find a way to power the lamps.
To power them from 120vac directly will burn the lamp out prematurely...like in less than a minute.
I considered a simple triac light dimmer circuit (which I had built years ago for another project) on each lamp, but the RF noise finds it way into my audio sound recording studio mixer/system.
I also considered a simple power resistor mounted to a heat sink, but I dont know to use ohms law to figure out resistor ohm value or watt rating. Does the resistor watt rating need to be that of the lamp (300 watt)?
Any creative ideas?
I dont mind building a circuit at all to accomplish this, but not sure where to start. thanks
Any creative ideas?
