keukenrol
Hi
the past few years I have been experimenting with different LED setups to make them reactive to music.
In order to complete my project I would like to implement the following things:
- A 16 x 32 LED matrix spectrum analyser (5V)
- A 2m WS2812B LED strip (5V)
- Stereo 2 x 8 LED VU meter
- Different R, G, B and W LED's across a wooden panel
- A RGBW LED strip (12V)
- A white LED strip (24V)
The goal would be to make a wooden panel of about 1.5m in the shape of a half circle. Mounting the white LED's on the outside to be used as strobes.
I have a few questions:
- Best power supply to use for the different systems working on different voltages
- Single controller option or every system with its dedicated controller, connected to one audio input
-> For example, my spectrum analyser is currently running a STM32F746G microcontroller. This one is calculating the DFT and is multiplexing the LED's -> HIGH Speed is required, unfortunately the ADC broke down due to a loose power supply cable hitting the ADC input (MAX 3.3V, power supply was 5V).
- Best ADC for stereo operations, I am currently using a DC offset signal because most controllers dont like negative voltages.
- Controllers to use? I have experience with nRF52 and STM32.
Idea's are welcome, the goal would be to have a system which can run on its own on music, or to be manually controlled (control panel should be made too).
Best regards
Tim
Best regards
Tim
