Homemade Arc inverter welder And Plasma cutter power
Re: homemade plasma cutter
Hello
Post other details like current .frequency....which switching topology you used?? Feel free to tell...
- regards
hi,
I've used the 300v power supply. arc starting by the spark gap tesla coil
Hi.
My amateur project , but very good working.
Hello devreci,
I have to say one thing, you are very brave doing the circuit on veroboard, especially
since the circuit is so complex.
I have to also say you've done an excellent job. Not only on the PCB, but also the transformer
and the rest of the set up.
Well done!!! :clap:
Regards,
Relayer
Thanks.
I am interested in electronics as hobby.
If I work gently, it will be torture, not entertainment.
This device (plasma cut) is very expensive in my country. 3 minimum wage.
I fixed the errors in the circuit drawing.
Other images
Current feedback bobbins
No load igbt gate oscillocope view +16v -16v
140A arc weld load gate view
30A arc weld very low load igbt gate gate view
It should not be a thinner wave because for igbt health
