It is a construction of small home made sandblaster. The compressor use for this project has only 24 liters and its efficiency is 206l/min. It also uses a 8 liter extinguisher. The sandblaster can be used for cleaning rust on paint etc. Small compressor is sufficient for that purpose and operates correctly with the 3mm nozzle.
Sand blasting using that device can tear everything down to bare metal. It works properly with the pressure of 2-3 bar.
List of elements:
- compressor
- extinguisher
- 2 valves 1/2
- hose
- knees
- tees
Pictures:
Link to original thread - Piaskarka ciśnieniowa ośmio litrowa za 40zł.
