Home made JCM 800 2204 in JTM45 style
This designed was a result of inspiration from this webpage: LINK. The main assumption was to create a similar construction to original Marshall devices. The design described here is JCM 800 2204 Master Volume in Plexi/JTM45 style.
Housing was made of plywood as in the original JTM construction. It was finished with black Tolex and Biz/trimmings were pasted. Chassis was done accordingly to the original drawings. Turret Board was made of phenylo-paper board, holes were drilled and soldering pins stuck, making the board more similar to the construction from the past times.
Panels were printed on golden self-adhesive film for ploters (Oracal) using old laser printer Brother HL5140. In addition, the print was protected with 2mm plexiglass.
Output transformer InMadOut, original Marshall handle, knobs, feet, Biz, Tolex, sockets, tubes stands, impedance selector and logo can be bought in a specialistic store such as Amptone.pl. The preamplifier uses tubes 12AX7S from Penta Laboratories U.S.A. EL34 EH operate in the power amplifier.
Pictures:
Link to original thread - Moja replika JCM 800 2204 Wykonana wizualnie w stylu JTM45
