Home made copy of distortion BOSS DS-1
This is a guitar effect DS-1 of own construction. Schematic and PCB were taken from tonepad, although a small modification was made. Housing was made of a painted metal tin. There is no space for battery, because the effect is powered by a charger from an old Nokia 1631 (10V 750mA). The PCB was mounted to the housing using two screws and two spacer pins based on the plate. Buttons are made of 6-pins isostats. Large metal pads are welded around them so the jagged holes are not visible. Knobs were removed from an old radio receiver. Output socket is a mini jack. All cables inside are shielded.
Schematic can be found HERE.
Modification consists of the possibility to change diodes cutting off the signal:
This allows you to reach sound in style of distortion on LEDs and something similar to FUZZ on germanium diodes.
Pictures:
Sample of sound:
Elements used:
  • laminate
  • etching
  • 3x 6-pins button isostat
  • 3x potentiometer
  • 4885
  • plastic spacer pins
  • screws
  • resistors
  • housing
  • rubber legs
  • DC sockets
  • jack
  • mini jack
Link to original thread - Kolejna kopia distortion BOSS DS-1
