Hollow shaft encoder
vikash23
Full Member level 2
Full Member level 2
I am looking for a hollow encoder .
Please see the attached image.
It'a a pump and I am trying to place the pump back to back so one is driver and other is a generator.
I need to measure the speed of the shaft always and I am looking for a speed measurement device like encoder or similar.
I have found the following hollow encoder but our shaft size is 10mm and the shaft size of this is only 6mm.
https://ecatalog.dynapar.com/downloads/F10_DS_702453_2_.pdf
Can any one please recommend me a cheap hollow encoder to measure the speed. ?
Or even if you can recommend a motor with encoder attached to the other side which can give a rpm min of 6000 is also ok.
The motor that comes with the encoder should be capable to 400W and must be less than £50
there are a lot of encoders. Hollow shaft and not hollow.
One manufacturer with many different types is: https://www.kuebler.com/usa/index.html
--> With an internet search you will find many other manufacturers.
And you will find any mechanical adaperts to adjust for different shaft diameters.
--> The encoder manufacturers will help you with this.
But you say "shaft speed measurement"...
(you didn´t give any specifcations about RPM range, resolution, precision, measurement interval...thus we need to guess)
I´d say there is no need for a true encoder.
Maybe a simple reflective sensor and some (painted) markings on your coupling device will do the job.
Klaus
I also had the idea initially but the reason I am looking for an encoder is because it's rugged and I dont want to break it any time as it's going to customers hands.
I searched for some reflective sensor and found the following
https://uk.rs-online.com/web/p/reflective-optical-sensors/8203181/
https://uk.rs-online.com/web/p/reflective-optical-sensors/1700731/
But how will I know what rpm it will measure ?
Our requirement is 6000rpm max . Resolution can be 10%. Not sure about the precision and measurement interval.
Or can i use some thing like this
https://uk.farnell.com/broadcom-lim...r-8mm/dp/1161087?MER=bn_search_1TP_SearchNB_1
I recommend to use one with timing specification in the datasheet.
You may also have a look at these: https://uk.rs-online.com/web/c/disp...s-photointerrupters/slotted-optical-switches/
10% resolution, this is 600RPM ... you are not interested in better resolution, then precision shouldn't be a problem either.
measurement interval:
I recommend to decide a range of value.
It surely depends on how you want to process the RPM value.
I designed applications with a processing rate of 1.6ms up to 15 minutes.
Just to be displayed: I recommend 300ms ... 1000ms
Klaus
