Highly efficient and stable wall-mounted SIP network active speakers
sinrey
Newbie
Newbie level 3
Sinrey SIP741V Network Active Speaker, as a highly efficient and stable wall-mounted SIP network active speaker, it integrates the essence of modern audio technology and network communication and is designed for users pursuing high-quality audio playback experience. With its excellent performance and convenient operation, this speaker sets a new benchmark in the field of network audio playback, demonstrating exceptional audio performance and reliability in both daily applications and professional settings.
SIP protocol is fully compatible to ensure stable communication
SIP741V speaker fully supports SIP protocol v1 (RFC2543) and v2 (RFC3261), a feature that enables it to maintain stable communication in complex and changing network environments. Whether it's an internal IP phone system or a cross-regional teleconference, the SIP741V can be easily accessed to ensure seamless transmission and clear presentation of audio signals.
TCP Playback Protocol Support, Enhanced Data Transmission Quality
In addition to the perfect compatibility of SIP protocol, SIP741V also supports TCP playback protocol, a design that further enhances the stability and reliability of data transmission. Through the TCP protocol, the speaker is able to handle network delays and packet loss more effectively, ensuring the smoothness and continuity of audio playback and bringing users a better listening experience.
High power output, shocking sound experience
As a professional-grade active speaker, SIP741V has a built-in amplifier module capable of outputting up to 20W of power, which can easily cope with both daily background music playback and emergency broadcast notification. In addition, it also supports an external 20W subwoofer (to be purchased separately), through the expansion of the bass unit, to further enhance the sound effect of the sense of hierarchy and shock, so that every playback becomes a feast for the ears.
POE power supply, convenient installation and maintenance
SIP741V innovatively adopts POE (Power Over Ethernet) power supply method, which means that only one network cable is needed to realize data transmission and power supply at the same time, greatly simplifying the installation process of the speakers. At the same time, POE power supply method also reduces the requirements for the installation environment, so that the speaker can be flexibly deployed in a variety of scenarios. In addition, due to the reduction of the use of power cables, also reduces the failure rate and maintenance costs, for the user to bring a more convenient use of the experience.
Easy to operate, powerful
As a SIP terminal designed for network audio playback, SIP741V strives for simplicity and efficiency in its functional design. It supports a variety of audio decoding formats such as G.722, G.711A/U, MP3, etc., which can easily adapt to the needs of different application scenarios. At the same time, the speaker also supports setting up to 10 multicast zones with prioritization, which meets the demand for partitioned playback in large venues or complex network environments. Users can realize flexible audio management and control through simple configuration.
Conclusion
SIP741V wall-mounted SIP network active speaker brings users an unprecedented audio playback experience with its comprehensive SIP protocol support, efficient TCP playback protocol, powerful power output, convenient POE power supply, and simple and powerful functional design. Whether for commercial office, education and training, or leisure and entertainment, SIP741V can be your ideal audio playback solution.
