High voltage transistor
te04-0202
Junior Member level 1
I need to attenuate 220 Volts @ 50 Hz by using a high voltage transistor(MPSA44 maximum 400 Volts) by implementing a high pass filter.
Can this be possible.
Please help me.
It is possible. I recommend IRF Z44. It's a power mosfet. It should do the job. IRF 540 isn't bad, but Z44 is better. Hope this helps and don't forget to press the helped button.
    te04-0202
