Gaber Mohamed Boraey
Full Member level 5
Hello
Can I replace ksp44 transistor within 13001 ?, high voltage transistor
Above the data sheet for both, please look and advice
I think they can be replaced, but I would like for sure your advice also
Thanks in advance
13001 Download
Download 13001 Datasheet. File Size: 184.32 Kbytes. Part #: 13001. Description: NPN Silicon Epitaxial Planar Transistor. Manufacturer: SEMTECH ELECTRONICS LTD..
pdf1.alldatasheet.com
KSP44 Datasheet, Voltage Transistor.
KSP44 Transistor Datasheet pdf, Fairchild Semiconductor, KSP44/45 KSP44/45 High Voltage Transistor • Collector-Emitter Voltage: VCEO=KSP44: 400V KSP45: 350V.
datasheetspdf.com
Thanks in advance
