HINDI
Member level 3
- Joined
- May 1, 2004
- Messages
- 56
- Helped
- 2
- Reputation
- 4
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- MISR "EGYPT"
- Activity points
- 622
Hi
i am using msr860 as a free wheeling diode across the h- bridge mosfets for both the high and the low but after a short while of operation it fails and goes cocked and then shorted "1 minute ".
it was noted that the -ve portions due to the back emf of the voltage signal had been removed after adding the freewheeling diodes but still there is a high voltage spikes on the riesing edges of the switching signal .
where the h- bridge is 24VDC 15 amp , and 20khz .
i don't know what may cause although it has a sutable ratings for may load .
so , what may cause this problem ?
and how to remove this rising edge spikes ?
salam
hindi
salam
hindi
