a.singh123
Newbie level 5
I am designing a DC High voltage power supply, using PSM technique. I need to control it in a feedback loop, for which i need a resistor divider at the final output. Output is a pulsed high voltage around 1000 Volts of frequency 20 kHz.
This high voltage pulse o/p needs to be attenuated down to 5 volts range using resistor voltage divider. I used a 5Mohm resistor with 20 kohm resistor in series, and then fed it to the OPAMP voltage follower ckt, but the output is very noisy. Please suggest how to get clean output. Actually my final objective is to low pass filter the pulse wave to get its DC value.
Regards,
Abhishek
Regards,
Abhishek
