Zak28
Advanced Member level 2
![Advanced Member level 2](/styles/images/ranks/glevel2.gif)
Would a TO-247 aluminum heatsink uninsulated to the to247 tab which is switching 0-1100v induce major voltage spikes to any nearby components pads or traces on the board?
is the tab connected to the the drain, or the source, or is it isolated?
what is the switching frequency and desired rises/fall time?
without any other information, i'm going with yes it will cause spikes
Sounds like you have no realistic idea of switching noise propagation. The said electrically "hot" heat sink must be expected to couple capacitively into high impedance circuit nodes and possibly also radiate EMI. But it hardly affects low impedance nodes like the gate circuit dierctly. The strongest coupling between switching drain and gate node is inside the FET, by the way.How far away then does a gate-source TVS diode need to be from the gate pin since the high voltage noise would cause it to constantly clamp?
Another effect to be considered is that capacitive loading of the switching node causes ground return currents which may affect the control lines to the gate driver and the control circuit in general.
