High-voltage circuit board
Rogerlu
As for help: The maximum voltage 100Kv 50cm * 50cm board thickness of 2-3 mm , with a minimum consumption of audio what the best board material can be chosed ?
100kV and audio on the same board.
100kV is dangerous...and "audio" sounds like a consumer product. This is not a good combination.
Limited safety and random users.I don't like the idea.
Each country has it's own safety regulations...i recommend to have them all by hand.
Usually there are recommendations on plastics in those papers.
I assume for that high voltage epoxy is a good choice.
You need a huge air gap and huge creepage distance.
Be careful.
Klaus
Thanks for your suggestion, it is indeed dangerous to use 100kV with audio, that is why I wanna find a kind of board material that can bear the high voltage to reduce danger.
i recommend to use seperate PCBs and potting of the complete 100kV part.
Klaus
You are not going to get 100kV on a PCB.
You need to supply more details of what you are trying to achieve? A 100kV is not the sort of voltages that you get on PCBs or what you want to be playing with, it is mains distribution voltage......
