High Speed PCB design:REQ
hatemius
Hello All, I have small Project and I need some help from you guys
My project is to design High speed PCB to connect CPU to couple of external memories.
If you were me how could you defines:
- PCB stackup (2,4,6,8 layers!!!).
- Trace design based on I/O driver!!! how!! what!!.
- PCB terminations for these signals: RESET, CLOCK, DATA BUS, and ADDRESS BUS!!! I though I only have CPU and memory there these signals come from!! DO I have clock in my board!!!! heeelp.
- address and data bus used 100MHz syn. bust SRAM.
- what is clock tree distribution!!!.
- do I need to add clock to my design (CPU + Memories + clock)!!!.
- how could I connected them (memories) to let the signalto arrive at the same time.!!!
-Is my circuit layout mow only CPU and memories connected with couple of trace lines!!.
I new for this design so any advise will help.
