high speed flash adc design issues
tripathishubhang
Newbie level 5
Newbie level 5
adc design
hello friends...
my project is design of high speed flash adc ..as a starting i am using tiq cmparator n doing the simulation in microwind,i have a few questions...
1. suggestions on some other simulator.
2.urgent ..what is the value of threshold voltage of pmos i.e. i m keeping the nmos width constant and varying the pmos width to get various switchings but at times the calculation of pmos width is coming negative...what to do...
3.how to improve the speed of adc..
all kinds of suggestions to above topics as well as any other suggestion is highly appreciated...
thank u....
adc design
1. It depends: are you concerned about cost, performance, ease of use...? The industry standard is Cadence, some people like HSPICE, some like Eldo...
2. Why don't you change the nmos width??
3. In a flash adc, the speed is mainly affected by the comparator design. Without any more information, this is as much as I can tell you.
Re: adc design
thanx for the suggestion..
i am simulating it on microwind...can u kindly suggest some values..
regards..
shubhang
adc design
43.
How am I supposed to suggest any value??? Are you a designer??? Use your imagination, try different things, see what affects the results...!
