funberry
Junior Member level 1
high side mosfet driver
I am working on a Full Bridge offline SMPS using high voltages.
I had bought the Fairchild FAN7371 high side MOSFET drivers to drive the high side FETS.
https://www.fairchildsemi.com/ds/FA/FAN7371.pdf
I thought I had this thing worked out and was blissfuly content.
Now Fairchild just came out with a newer high voltage hi-side driver , the FAN7085, which features a "racharge FET"
https://www.fairchildsemi.com/ds/FA/FAN7085.pdf
The only documentation Fairchild provides about this novelty is the sentence:
"Built-in recharge FET to refresh bootstrap circuit is very useful for circuit
topology requiring switches on low and high side of load."
Ouch.. You mean the FAN7371 was NOT suitable for topologies with both hi-and-lo side switches?
I can't use the new FAN7085 because it only goes to 300V, and my high side is 335V DC (220VAC)
Are High-side drivers like the FAN7371 (and many others) generally NOT suitable (or not intended) for full bridge topologies?
Is it because the load is lifted off the ground by the low side switch, and the hi-side driver cannot "see" the ground properly to charge its bootstrap circuit?
Doesn't make sense, since, during the OFF cycle, the low-side MOSFET of the opposide pair of switches grounds the load ( in fact grounds the low-side node of the FAN7371), which should provide the 7371 with plenty of opportunity to conduct current to ground.
I don't get it...
Is there any workaround to use hi side drivers in full bridge topologies?
thank you
Andy
I don't get it...
thank you
Andy
