High Side driver with integrated charge pump for automotive
Vauxdvihl
Member level 5
Member level 5
charge pump high side
:wink:
Hi friends,
i search a High Side driver with integrated charge pump for automotive.
Can somebody give me some tips ??
Thank you very much
Regards
charge pump high side driver
You can try with the HIP4081 H bridge driver
Also there are a lot of intelligent switches, for example, search in International Rectifier the Intelligent Power Switch (high and low side), but they are not very fast (ideal for frequencies below 20kHz or relay replacement).
Good luck
high side driver 20khz
You have also Infineon, ST, Linear technolgy, Vishay
Jzo
high side driver charge pump
The IR2110 has not an integrated charge pump as Vauxdvihl ask for.
Regards
gate driver charge pump infineon
Hi
the ir2110 alone without the bootstrape has the ability to drivie the gate with only a few mili amp , but using the bootstrap capacitor its driving signal will be nearly 2 AMP.
best regards
