krishnakumard
My requirement is to digitize completely the incoming pulse (Gaussian nuclear pulse from the preamplifier/delay line amplifier of about 2 micro second width and 0.5 - 5 V height ) and carry out the further signal analysis in the DSP. To be more precise, I need to digitize each pulse into many samples. I need to analyze these samples individually. For example, first sample of the pulse at time t1, second sample of the pulse at t2 etc.. Last sample of the same pulse at time Tn. This will lead voltage samples of the incoming pulse with respect to time. I need to get this information for all incoming pulses to deduce rise time characteristics of the incoming pulses. In short, pulses are to be segregated out with respect to its rise time characteristics as I would use a phoswitch detector as the sensor.
For this purpose I need an ADC with high sampling rate for this requirement (is 100MHzall right) and a DSP for signal analysis ( to exclude noises and segregate signals) and store it in the memory.
Most of the ADC's comes with the DSP evaluation kits are SAR type for example AD7266(2MSPS) for Analogue devices. But I was told that all SAR type ADC's are peak detection ADC's. it will only detect the peak voltage and convert it into digital value. Whether SAR of high speed of the order of 10-100MHz will chop the incoming pulses into many as I described earlier and my problem would be solved. Please throw light into it as I was stuck up due to ADC selection.
Thanks
with regards
Krishnakumar
Thanks
with regards
Krishnakumar
