covman
Newbie level 1
Hello All,
As a newbie in our forum, I honestly haven’t got much experience in any electronic projects in the past. So please bear with me.
I have recently been asked to provide a solution for monitoring the misalignment (distance) of two objects within a short range (up to 30 cm). My task is to propose a cost effective solution that can monitor the distance between these objects and also meet requirements as shown below:
1. Accuracy: <= 0.1 mm
2. Update rate: >= 100 times/second
3. Maximum distance range: < 30 cm
Can I use ultrasonic distance sensors (mount trigger and receiver on these objects separately) for this task? If yes, where should I start? If not, which other solution I could consider? Any comments or suggestions will be much appreciated
