high performance and low power
invincibleuiu
hello,
i want know about high performance standard cell and its parameters and characteristics ...please help me about this...
1.what is it definition...
2.advantages......
thanks
Are you talking about a specific device?
Then tell us.
Most probably you find the answer in the datasheet. It may be a problem of speed versus power consumption.
Klaus
hello,
2.advantages......
thanks
Whenever you want a good performance and speed and ready to compromise for the area constraint than High performance cell libraries are used.The number of tracks will be more so proportionately even the transistors sizing will be more.
Actually I need the definition for general device , so that it can be fitted for any specification.
when you mean by high performance....
there are many other aspect to it.
Such as: power, timing, size and most of them contradict to each other.
Like there is compromise between speed and power. (current trade)
If you are newbie : Think about the best performance car:
it may be high speed, high power, high millage ...
So be specific and you may find your answer.
there are some basic parameters you can use:
area of cells on normalized scale for nand2 gate : 4transistors per nand2 gate .....so a flop with 28 transistors is 7nand gate.....compare their area....
The smaller the better.
No. of tracks : 9T , 7T library another performance parameter..
No. of VT's :
Different kind of flops and area of the flop.
This is marketing lingo.
For ARM devices
High Performance libraries are 20% faster than High Density mainstream libraries
Ultra High Density versions based on smallest cell height require 20% less area and power than mainstream libraries
