KMN1
Newbie level 6
Hi I'm trying t o setup the LT1249 boost PFC controller to work with an input of 24Vrms to obtain an output of 60V at 5A. I've set the reference voltage parameters according to the datasheet here https://www.analog.com/media/en/technical-documentation/data-sheets/1249fbs.pdf
Considering the load is around 12ohms I was not able to obtain a smooth output voltage waveform instead the output voltage is oscillating at a voltage lower then the input voltage.
Does this mean the IC is not capable of handling heavy loads or is the input voltage too low?
If so would a power amplifier set as a voltage follower be a feasible solution? (only problem is it needs to be biased at a voltage above 60V to work)
I've attached an ltspice simulation
