thanksPGA202 possibly. It has digitally programmable gain in steps of 1, 10, 100 and 1,000.
Brian.
thanks this is really helpfulThe bottom limit is defined by noise. If you measure a DC voltage, check the opamp 1/f noise and use a low-pass filter to limit noise bandwidth. You also have to define the input impedance to refer the noise power and voltage. The higher the imedance, the higher the noise level.
If you refer to audio frequency range, then there are many mV meters with that range, even down to a fraction of a microvolt.
thanks i'm gonna stick to ADC cause i need to process the information with a micro controllerI think AD620 is a good choice for your application. I do not work with ADCs but for signals < 100 Hz,AD has some *** ADCs with a refresh of 100 Hz or more. You can try a low-cost DVM which can directly read from ~1 mV AC upwards and with the added AD620 amplifier from microvolts. Some DVMs have an USB link to PC and come calibrated.
