High Impedance Transducer Considerations
electrik1
Newbie level 2
Newbie level 2
hi all. I want to work with a high impedance transducer(Mega ohm order) and I was wondering about the matters that I should consider. do I need to use an opamp with special specifications? what about matching considerations?
If this impedance is so high your signal might be a current, or charge signal. Use charge or current amplifiers.
__________________________________________________
Low-cost resistors, capacitors, and LEDs: **broken link removed**
