High Impedance in Verilog-A
bajji_boy
Newbie
Hi everyone
I was wondering if there was a way to model a floating node in verilog-a. I was actually working on a simple model for a switch (including its on-resistance). What is wish to do is to 'float' the output node when the switch is off...
Cheers
Nihit
You can do two things, either a large Roff or open switch. I prefer the first for simulation converging.
So when you have
V(in,out) <+ I(in,out) * Ron;
in the on state, you would have either
V(in,out) <+ I(in,out) * Roff;
or
I(in,out) <+ 0;
Hope this helps.
    bajji_boy
Thanks for the response solidstate
I tried the latter, I(in, out) <+ 0, but as you guessed, it gave me convergence issues since V(out) was connected in a feedback loop.
I will be probably try the first model and get back to you...
Cheers
