Plecto
Full Member level 5
- Joined
- Jan 4, 2012
- Messages
- 315
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,298
- Activity points
- 4,979
I have a sound level meter in my living room that is extremely sensitive. It uses the electret mic from a cheap cell phone and an ordinary opamp, not a low noise audio opamp. If there is no sound from anything then it shows me breathing many meters away. When I hold my breath then it shows the quietness of no sounds that you want.
You will need both:I got another idea though, what about using a LM393 comparator instead?
Why would I need an amplifier?
I see a few problems on your schematic:
1) The power supply has a half-wave rectifier which causes ripple. Use a full wave bridge then the ripple frequency is doubled allowing the filter capacitor to filter much better and/or be smaller.
2) Your opamp is in an inverting circuit with a very low input resistance of only 1k which kills most of the output level from the mic. Instead the opamp should be in a non-inverting circuit like mine in post #9 with an input resistance of at least 27k. Mine is 97k.
3) I do not see how the opamp is powered.
4) The TLE2142 is a dual opamp, how will you use or disable its second opamp? Maybe you should use a TLE2141 single opamp instead?
You have a resistor R26 in series with the regulator output....again, why?
It seems to be an EAGLE schematic.
You make it unnecessary difficult:
* Why don´t you connect the signals by using "net" command and connect one part/pin with the other part/pin? Then it automatically creates the connection "dots" and everybody can see if it is a crossing of two independend signals or "one" signal.
* Why don´t you use the "value" command?
* avoid crossings
* avoid wires crossing a symbol.
* use VCC (or similar) symbol.
