High duty cycle boost converter
eem2am
Banned
hello,
i need a high duty cycle boost converter ic (pwm controller)
i need to boost from 2v to 25v and with 3 Watts output power
does any body know of such a high duty cycle IC?
Take a look at this:
Hope it helps.
Tahmid.
Added after 4 minutes:
Take a look at the datasheet of MAX669:
http://www.datasheetcatalog.org/datasheets/400/443791_DS.pdf
3W o/p Power = 25 o/p voltage * unknown o/p current.
So o/p current is too low.
for these you don't necessary high duty cycle.
calculate simply boost converters capacitor and inductor for the same.
what about your load? is it 3w?
Powerpatrik, I don't see your point.
I think if ee2am talks about 3W output power, he has a reason for that. 3W/25V = 120mAmps.
thankyou,
but we really need something with 99% duty cycle and it doesnt exist.
does any reader know of a push pull ic for this job...with on-chip fets?
I only see 92% duty cycle.
If this is still a problem, you can try a two step system. 2-->7 and 7-->25 (two times around 72% duty cycle)
