Amr Wael
Member level 5
Hello ,
I want to design a current measurement circuit using a shunt resistor that's capable of measuring up to 20Amps and can tolerate over 220 V common mode voltage.
I decided to use a high side topology in which the shunt resistor is connected between the supply and the Load. i Narrowed down my choices to TI (INA149) and Analog devices (AD629). Those are high common mode voltage differential amplifiers that are capable of measuring the voltage difference on the shunt resistance. My problem is that I would like to use a resistor with a range of 10m Ohms or 5 mOhms to minimize the power disspiation but at the same time I found error budget analysis at the Datasheets of both ICs that show that the error is around 1.6% at a full scale voltage of 1V when using a resistor of 1 ohm which obv. carries a current of 1 A.
Based on the analysis I concluded that the error will be further more higher in case I decrease the shunt resistance value.
My question is How can I use such an ultra small Shunt resistance without losing accuracy?
Thank you very much in advance.
