ecksray
Newbie level 2
Hi!
I have a number of LiIon battery-powered applications with the following voltage/load power:
24V, 250W
36V, 250W
36V, 350W
48V, 350W
48V, 450W
(a.) A 12V/1.2A output is needed in each instance to run some auxiliary loads. Already experimented with putting together a voltage regulator using LM317. But this IC gives off a lot of heat even at just 180mA, considerably warming up the batt compartment, which is already near the maximum design temp. limit for the batt when the main load is running at full power; in a hot summer day I’m afraid it may melt the wire wrapping or plastic insulations. Any advice for other better alternatives which are reasonably cost-efficient?
(b.) I want to have the option of swapping around the batteries at will to run the different main loads, e.g., using a 24V battery to power a 36V load, or using a 36V battery to power a 24V load, or using a 24V battery to power a 48V load, or using a 36V battery to power a 24V load, etc. I’m thinking of building a voltage regulator, ideally, only one regulator design is built to handle all different input voltages to power the different loads. Any suggestions on ICs/schematics for a regulator design that has minimum circuit complexity and minimum heat dissipation?
Many thanks!
24V, 250W
36V, 250W
36V, 350W
48V, 350W
48V, 450W
Many thanks!
