jasmine123
Newbie level 5
module modified_vedic_multiplication(q1,u,q2);
input [19:0] q1;
input [19:0] u;
output [19:0] q2;
wire [31:0] d,g,temp1,temp2,temp3,e;
wire [15:0] temp4;
wire c1,c2,c3;
wire [7:0] f;
vedic_16bit y0 (q1[15:0],u[15:0],d[31:0]);
vedic_16bit_modified m1 (u[15:0],q1[19:16],g[31:0]);
vedic_16bit_modified m2 (q1[15:0],u[19:16],e[31:0]);
vedic_4bit m15 (q1[19:16],u[19:16],f[7:0]);
assign temp1 = {4'h0,d[31:16]};
full_adder_32bit_reversible r0 (e[31:0],g[31:0],1'b0,temp2[31:0],c1);
full_adder_32bit_reversible r1 (temp1[31:0],temp2[31:0],1'b0,temp3[31:0],c2);
assign q2[11:0] = temp3[15:4];
full_adder_16bit_reversible r2 (temp3[31:16],{8'b0,f[7:0]},1'b0,temp4[15:0],c3);
assign q2[19:12] = temp4[7:0];
endmodule
module full_adder_16bit_reversible(a,b,cin,sum,carry);
input [15:0] a,b;
input cin;
output [15:0] sum;
output carry;
wire c;
full_adder_8bit_reversible a12 (a[7:0],b[7:0],cin,sum[7:0],c);
full_adder_8bit_reversible a13 (a[15:8],b[15:8],c,sum[15:8],carry);
endmodule
module full_adder_8bit_reversible(a,b,cin,sum,carry);
input [7:0] a,b;
input cin;
output [7:0] sum;
output carry;
wire c;
full_adder_4bit_reversible a2 (a[3:0],b[3:0],cin,sum[3:0],c);
full_adder_4bit_reversible a3 (a[7:4],b[7:4],c,sum[7:4],carry);
endmodule
WARNING:Xst:1290 - Hierarchical block <a13> is unconnected in block <a10>. It will be removed
from the design.
WARNING:Xst:1290 - Hierarchical block <a13> is unconnected in block <a10>. It will be removed from the design.
WARNING:Xst:1290 - Hierarchical block <a13> is unconnected in block <r2>. It will be removed from the design.
The simulation result is correct, but I keep getting these warnings. The trouble appears to be in the a13 module. But I am not able to figure it out.
