Hi , i need to make this circuit in protus program
okman
Member level 1
Member level 1
You mean Proteus?
What stops you?
Alex
Reactions: okman
    okman
hi
so what can i do for you my dear??? caryon
t/c
bye
Reactions: okman
    okman
hi
hhh ok thanks alexan_a & qayyoum
this cct in "proteus"
now i need pulse to the two IRG4BC10KD
because i dont know how to use pulse in proteus
hint : i need any pulse tool
this cct View attachment p.rar
You can access the sources from the following icon
Use the pulse source (the attachment was from a reply in another thread so it was showing how to insert an AC source, ignore the arrows)
Alex
Reactions: okman
    okman
please help me
i am will crying.............
i don't know how to turn this circuit because i don't know how to trigger the switch
i need somebody turn this circuit and send it to me
the circuit is :
  • kk.rar
okman i have seen your circuit it dont have any switch. i didn't understand what "i don't know how to turn this circuit because i don't know how to trigger the switch" means.
Your question is unclear.
Reactions: okman
    okman
ok, don't care and i am sorry
the circuit is designed in proteus program
i don't know how to trigger the IRG4BC10U (IGBT)
when you run the program the circuit it turn but the out put voltage is very low because i could not to trigger the IGBT
thanks
the circuit is here
  • kk.rar
To Turn On the IGBT you have to apply voltage greater than the threshold voltage at gate terminal. I dont know the the threshold voltage of the IGBT you are using. See its datasheet. If you simply apply DC voltage on gate greater than threshold voltage IGBT triggers and turn on. For this there is a terminal mode present in the left pane of your Proteus window,click on that and select POWER than place it in the schematic and connect it to the gate terminal.Now to change the voltage right click on the POWER model and then click Edit Properties and in the string field type the Voltage you want (e.g 2.56v,5v,-1.28v etc). If you want to give a PULSE to the gate of IGBT you can find it in left pane in generator mode and to change its freguency etc just right click on it and go to edit properties.
Hope this helps
Reactions: okman
    okman
hi
this cct View attachment 65313[/QUOTE
hello,you should feed this circuit with micro controller like pic 628 available in component mode that have a default +5v rail but you have to connect the gates through 470 ohm resistors and also have to provide the ground to the gates through 22k resistors.having been completed,play the same,you'll get the pulse on oscilloscope as well as on dc meter .
Reactions: okman
    okman
thanks ch wazir and all
please please ch wazir
this the circuit with pulse from 555View attachment Desktop.rar
but this circuit dont work
why??
please help me because if i learn to turn this circuit , i will able to design the circuit that i want.
this the circuit with pulse from 555View attachment 65515
why??
dear okman,
I am not looking yours provided circuit,if I can,I must help you.Regards
Reactions: okman
    okman
why??
Dear Okman,
I am making yours given circuit on my proteus,I'll inform you after a bit while.Regards
Reactions: okman
    okman
ok,
I am waiting .......
Dear Okman,
I have made yours given circuit in proteus and found that the IGBT no.IRG4BC10KD you picked from the library seems to be a spice file(compatible spice component) which can be used with advanced engineering skill and it's a quite lengthy procedure to make yours good self understand,however you may pick it from help menu.
You may pick another IGBT like IRGB14C40L lying default in liberary,replace it and the simulation will start.
However your given circuit is pretty good one and practically workable provided you feed the IGBT with reasonable voltage.Regards
