iby121
Newbie level 1
Hello i need some help on the following questions cansum1 kindly plz help thank u very much.
the questions are:
1. write the data type and structure of an IP4 address?
2. what is the data type of the new IPv6 address?
3. An example of an IP4 address of a host on a Class B network?
4. A class C IP4 address has the first three bits reserved to 110. write the range of decimal values that the first field of a class C IP address can take.
5. what is the purpose of IP addresses whose first field decimal values are above the upper limit of class C addresses?
6. "every host on an IP network is identified uniqueky by a single IP address". what kind of hosts are the exception for this statement and whY?
8. sketch and label the four layer hierarchical functionality model upon which the software engineering of TCP/IP communications stack is based.
9. Describe accurately the functionality of TCP internetworking layer
any links etc... thank you
the questions are:
