HFSS V11 Crashes by open a file...
minehunter
Newbie level 3
Newbie level 3
hfss video card
Installation no problem.
It hangs by opening my files also the example files.
PC:
3GHz PIV 2,5GByte RAM, Win XP, GeForce FX5900, newest driver.
The support told us, to chekch the newest driver for video card, we did it.
The other work stations ( PIII 1GHz, 1GByte RAM and a old video card (Geforce GTS 2) runs quick and good.
Maybe any user can help or has the right idea?
Minehunter
If you bougth the tool Contact the sales Team.
We did. The information that we got is to change the driver for video card.
No way...
An older driver runs a little bit better, for a few seconds.....next time we will change to CST...
O.K., lets see if there is any other user and could help me.
Minehunter
Is there any HFSS example file that you can open without a system freeze?
No.
Also my V10 files don`t run.
How older the video card driver is, so much more it is possible to see for a short moment my antennas and filters.
Our old work stations (10) with GeForce 2 GTS, no problem.
We also decreased the graphic speed in Win XP, same problem.
The message is: memory problems in 00000 do you want to debug...
Minehunter
I would check system memory. Use memtest86! I've installed HFSS on many PC configurations, almost all had GF graphics card and not one problem (v10, v11b, v11 ... all solid rock).
I will check this.
Give you the report in the next few hours.
Thank you.
Minehunter
