shlomo22
Member level 4
ic transformer
I want to use HFSS to simulate a RF-IC spiral transformer.
I have succeeded in simulating a single coil spiral inductor, and get the right inductance using the following formula: L=-1/2/pi/Freq/im(Y11)
Based on this, I want to use the following formula for mutual inductance: M=-1/2/pi/Freq/im(Y12)
But the results seem not quite right. The M values I get are negative, and worse, they have a larger magnitude than the L values! That should be impossible since M=k*sqrt(L1*L2) and 0<k<1, right?
Any ideas about what’s going on? Thanks!
My file is attached
My file is attached
