HFSS Reflectarray Scattered Fields?
ignatomic
Newbie
Newbie level 1
I am trying to simulate a reflectarray which is being illuminated by a horn antenna (with a waveport excitation). I am using FE-BI boundaries for the horn antenna and the reflectarray. The problem I am having is that in the results, I am seeing both the incident fields from the horn antenna and the scattered fields from the reflectarray, but I would only like to see the scattered fields. How would I do this?
In the attached screenshots, one shows the radiation pattern in HFSS, and in another, I outline the portion which is the reflected/scattered field, and the portion which is from the horn antenna
LaTeX Commands Quick-Menu:
